Designer100 Posted December 29, 2021 Share Posted December 29, 2021 I cannot get roof to work on right side of house to work out. . I would appreciate anyones help. 8:12 on for gable. rest of roofs are 4:12. Remodeling additional. dark shaded walls are new walls. Has to be kept in ver 12, because client wants to be able to pull up in chief 12. Thanks in advance. Newell Cheatheam Chief 12 924 Cortlandt.zipFetching info... Link to comment Share on other sites More sharing options...
SH_Canada Posted December 29, 2021 Share Posted December 29, 2021 your long gable is at 4:12 across 72', this puts your roof height at 12' at the peak. you side hip (not connected) is 17' at 4:12. this gives you roughly 6' at the peak, so short 6', which can be seen in a cross section: so to fix it, you would have to change the pitch of the hip, or build a wall or run the gable all the way across Link to comment Share on other sites More sharing options...
