Reference Display Set Wall Fill Settings
ForinoCo
Go to solution Solved by rlackore,
Hi Everyone,
Recently upgraded to X13, and a designer I work with sent me a plan file to work on. In previous chief plan files, the reference display would show the floor above with simply red outlined walls to make it easy to verify things line up properly. Now, you can see the walls are filled solid with color in addition to red outlines, but it is making the view very cumbersome to determine which walls are the floor I am actually on vs the reference floor over top. Does anyone know what I am missing to make the 2nd floor reference walls to not have any fill in them like the 2nd attachment shows?
