7seat852 Posted December 17, 2014 Share Posted December 17, 2014 Please help; How can I get Chief to locate the Rough Openings correctly. I have tried modifying the defaults by using the Rough Opening button, with and with out the Sides button and neither way is accurate. With out the sides active, the RO is an inch to big on windows. With the sides and RO clicked it shows a extra 1/2'' on the sides. With just the sides the center or framing between multiple windows is an inch to big, the three inches is increased to 4". If I try using the center locate, I still end up with 4 inches between the windows when there should only be 3 inches Any ideas or help would be appreciated. Link to comment Share on other sites More sharing options...
ebdesign Posted December 17, 2014 Share Posted December 17, 2014 Are you talkin' 'bout windows or doors? w/ windows, the frame is included in the unit size. w/ doors, the frame is not included in the unit size. Other than that, you'll need to post the plan or some screen captures at the very least. Link to comment Share on other sites More sharing options...
