X-13 When hitting fill window no plan. Can someone please help me.
CUBRAD
You have a polyline solid way out in space.  Switch to your All Off Layer Set, turn on your Polyline Solid Layer, group select everything in your building area using a marquee, Cut to your clipboard, Select All, delete, and then Paste Hold Position to put the previously cut items back in.
