Specify Label for Concrete wall thickness
Camerops
Go to solution Solved by Alaskan_Son,
I have a defined wall type with exterior insulation (2"), concrete (10"), Interior Insulation (.75"). When I specify wall thickness it returns 12.75". This is obviously correct technically speaking. However I would like to have it display the upper wall thickness which is 10".  User defined: object_properties shows a whole lot of values  including "Upper_layers[1] material_data Formatted_size".
How would the syntax work that display this attribute value?
On 7/29/2021 at 10:32 AM, Camerops said:
Got it %upper_layers[1].material_data.formatted_size%
THANK YOU !!!!
You're welcome.  I just assumed the percentage signs went without saying if you were putting it directly into a label.  Just as a quick side note, but beware that your macro as written will always only return the information for your second wall layer.  If you add another exterior layer, or another main layer above the concrete, you may get undesirable/incorrect data.
