SH_Canada Posted July 18, 2021 Share Posted July 18, 2021 This is all I found when searching the forum, but it is not the same but it is a similar theme: Change Birdmouth Of Rafter After Roof Plane Is Built - General Q & A - ChiefTalk Forum (chiefarchitect.com) I created a rectangular house and auto built a trussed gable roof with a 8:12 itch and a 16" energy heel using the "raise off plate" in the Build roofs dbx. All is good, section shows correct heel height. . I then I edited the roof planes to change the ridge location: I then changed the right side roof plane ridge to match the left side, and locked it, which forced the pitch change on the right side. All is good, including the section. But now my customer wants a different heel height. I do not see a place to do it in the Edit all roof planes dbx. And because the roof planes are now edited I cant put on the "auto rebuild" in the build roof dbx (Without it telling me it will remove my manually edited roofs) Is there a way to change the heel height AFTER the roof planes have been edited? or do i have to rebuild the entire rood and redo the manual roof planes? thanks Link to comment Share on other sites More sharing options...
Solution SH_Canada Posted July 18, 2021 Author Solution Share Posted July 18, 2021 thanks eric / @solver for future finders of this post: select roof planes click on transform replicate object check move in the Z delta, specify an amount to move check radio button "relative to itself" click ok force rebuild of truss result moved up by 8" as specified Link to comment Share on other sites More sharing options...
