DougDM Posted June 30, 2021 Share Posted June 30, 2021 So, I needed a few new defaults, 1', 1-1/2" 2" & 3" = 1'-0" I set them up as I normally set up a new Layer Set. via browser, edit new defaults. However, regardless of settings my leaders are not centering on associated text strings, Any idea of why would be helpful or a fix would be better. Thanks so much, Doug Link to comment Share on other sites More sharing options...
DougDM Posted June 30, 2021 Author Share Posted June 30, 2021 On 4/5/2021 at 12:53 PM, Chrisb222 said: Online 3D Models!! Understood and thanks for the update. Does that make me a fanboy? Eh, I don't downvote people that gripe because their gripes are legit to THEM. But for me, I just plug along and try to give a little back to this great forum. 1 hour ago, DougDM said: So, I needed a few new defaults, 1', 1-1/2" 2" & 3" = 1'-0" I set them up as I normally set up a new Layer Set. via browser, edit new defaults. However, regardless of settings my leaders are not centering on associated text strings, Any idea of why would be helpful or a fix would be better. Thanks so much, Doug Never mind, I figured it out....My text "LINE SPACING" in Rich Text is set as a default to 75%, cause the CA default is 100% (to much space between lines of text). Weird that it only affects scales of 1" -1'-0" and above. Below that I can keep my text spacing to 75% and leader centers as it should. Link to comment Share on other sites More sharing options...
