Wallpaper material not showing up in elevation view
ChiefTAB
Actually, it looks like it is showing.  It's just solid white though.
The view on the left looks like it is using the standard render technique.  The view on the right looks like it is using the vector view render technique.
Render views will display textures and vector views will display patterns.
It looks like your material has a texture but no pattern.  If you want it to display a pattern in vector views, you will need to add one.
More information about materials can be found in this video series:
https://www.chiefarchitect.com/videos/playlists/170/materials-patterns-textures.html
