Wondering if there are options for side mount railing systems such as the cable or rod systems that have the metal newels that are mounted on the outside of the deck.
Please post questions in General Q&A. Tips & Techniques is where you share your tips and techniques.
Please delete this thread via Moderator Actions near the top of the page.
    29506
    Berretta969mm
    Berretta969mm
  • Similar Content
    • By DeckQuestions
      Is there a way to make the top rail of my deck railing rounded?
    • By DeckQuestions
      How can I have a full post at the wall? If I uncheck the "half post at wall" option, the post vanishes altogether.
      Thanks.
    • By DeckQuestions
      My deck railings float off the edge of the deck if I change the thickness to 2 1/2" or lower. I need a 1 1/2" thick railing that stays on the deck.
      I opened an older project, and there the rails could go down to 2 1/2" before they started floating. Maybe a setting needs to be changed, or maybe that's just how the program works? Let me know.
      The pictures attached are of my black main deck at 1 1/2" rail thickness and my test deck at 3" and 2 1/2" rail thickness.
      Thanks.
      Salim.plan
