Elevation Line style change when sent to Layout?
M-Ferioli
When I send a wall elevation to a layout page, my dashed line style is showing up as solid.  This doesn't happen when sending the floor plan.  What is the difference there and how can I control that?
Thanks!
Mike
Did you choose "Use Edge Line Defaults" in the Send to Layout dialog?  If so, then you told the program to use the edge line defaults for the layout box instead of using the layer settings for the camera view.  If this is not what you did, then you probably need to post a plan and some pictures.
