M-Ferioli Posted April 5, 2021 Share Posted April 5, 2021 When I send a wall elevation to a layout page, my dashed line style is showing up as solid. This doesn't happen when sending the floor plan. What is the difference there and how can I control that? Thanks! Mike Link to comment Share on other sites More sharing options...
Dermot Posted April 5, 2021 Share Posted April 5, 2021 Did you choose "Use Edge Line Defaults" in the Send to Layout dialog? If so, then you told the program to use the edge line defaults for the layout box instead of using the layer settings for the camera view. If this is not what you did, then you probably need to post a plan and some pictures. Link to comment Share on other sites More sharing options...
M-Ferioli Posted April 5, 2021 Author Share Posted April 5, 2021 Dermot, Looks like that was the problem. I guess I've just never run into an issue with this feature before. Thanks for the help and the explanation! Mike Link to comment Share on other sites More sharing options...
