Can't select an item...
MAP6933
Sometimes when I need to select an object in my 2D plan I click on it and the Room highlights then I press the Tab key hopeful that the next object will be highlighted but it doesn't. The only thing that highlights is the Room period. This doesn't happen all the time but not sure what I'm doing to cause this.
