Manually adding Brick Veener
basilbabaa
It's just a furred wall type of a single exterior layer of 3 5/8" brick, nothing else.  Won't stop snapping back.
Is there any way to stop this insanity...  :mellow: or a better way to do this?  I guess maybe a Polyline solid?
Actually they are not the same.  I'm butting a steel building wall of 8"girts covered with 26 gauge corrugated steel panels against a 16" OC steel framed wall covered with brick veneer.  I want to then wrap the brick around over the metal to cover the gap and then flash it.
