Sroberts67 Posted February 5, 2021 Share Posted February 5, 2021 I've bought a couple onus catalogs that won't import such as lighted mirrors, has anyone else experienced this? Link to comment Share on other sites More sharing options...
Dermot Posted February 5, 2021 Share Posted February 5, 2021 You should first check to make sure that the catalog is compatible with your product and version. If you look for the little "I" symbol and hover over it, then you will see what versions it will work with. More info about importing downloaded libraries can be found here: https://www.chiefarchitect.com/support/article/KB-00090/obtaining-library-content.html If all else fails, then you might want to contact tech support. Link to comment Share on other sites More sharing options...
