How to see the dimensions/ measurements in an elevation?
HDDiana
This is the user forum for the Chief Architect professional products, Premier and Interiors.  The user forum for the Home Designer products can be found here:
https://hometalk.chiefarchitect.com/
Although there are no automatic elevation dimension tools, you can manually draw dimensions in cross section and elevation views in HD Architectural 2021.
More information about the dimension tools in the Home Designer products can be found here:
https://www.homedesignersoftware.com/support/article/KB-01002/using-the-dimension-tools.html
