Insert Symbol into Pony Wall?
kwhitt
I've created a recessed toilet paper holder for a client that is to go in the lower section of a pony wall (below shower glass) - see attached.  The new symbol (also attached) works fine on a standard wall, but not on a pony wall.  I've even tried using a wall niche to give me the cut-out, but no luck there either.  Anyone got any ideas on how I do this?  Thanks, Kevin
Recessed Toilet Paper Holder.calibz
18 minutes ago, solver said:
Open the wall and make the railing Solid. Probably will have some side effects, and I did not look at your plan.
Eric - I didn't get that error message the first time, but did after restarting.  That worked.  Thanks.
