Lost Library Items
Steve_Nyhof
1. Did you check the trash can?  If it's not there, was this a user library folder or one of the core library folders?  If it was a core, manufacturer, or bonus library, the easiest thing is probably to just download it again.  If it was a user library and you don't have a backup, well that's a problem.  If you placed any of the objects into a plan, you could always open the plan, select the object, and then add it back to the library.
2.  Just right click on the folder and export it to a suitable location.  See this help article for more info:
https://www.chiefarchitect.com/support/article/KB-00001/backing-up-chief-architect-content.html#User
It was a user library - I just recreated it. My Trash is empty.
I guess my library is under the data folder maybe - I will check that to back it up.
Thank you
