Mulled Windows Issue
johnny
  On 11/8/2020 at 1:09 AM, solver said:
What is "correctly"?
Expand
I'd say not offset from the outside casing...but i know there is typically a small offset chief shows (which i'm not sure of the logic there), but what I have now is nearly void of material thickness in-between the upper and lower window.  On your blue example to the right it does appear less drastic than the left...but when I mull the top and bottom window in the same file i get the same error.  Are you doing anything to get a different result?
