152431 0 Posted October 28, 2020 Thanks for some input here- I am trying to create a "multi approach" landing at the bottom of a stair run. When I attempt this, Chief forces a "joined angular" stair case....Which I could use in any other application than this one ; ). Could anyone please advise how I can limit Chief's auto build feature here and force the issue. Please see detailed attachment. Thanks Maximus Share this post Link to post Share on other sites
solver 1564 Posted October 28, 2020 Uncheck Allow Wrap on each stair section. I did not know how to do this -- just opened the stair dialog and reviewed the settings. Suggest you do the same when faced with a problem so you find a solution quickly and it will help your understanding of how the program works, and you might find other options that may help in the future. 1 1 1 Share this post Link to post Share on other sites
