BAGBOOG Posted November 9, 2014 Share Posted November 9, 2014 chief is one of the best software designer i have seen ,lately i downloaded over 10 cad programs.............. result.... the chief is by far the best when it goes to architect designing walls windows doors but to make a fast design you should be able to create your own library of pre configured items does any one know if you can do that and if you can ....pls How other thing would be nice to have the length and the angle of a line or wall attached to your courser like auto-cad does its much easier to enter the length and the angel while you draw Link to comment Share on other sites More sharing options...
lbuttery Posted November 10, 2014 Share Posted November 10, 2014 Chief uses a different method for drawing walls and it works very well watch some of the training videos and once you understand the method it will be "easy" yes, you can create your own library of items you can copy the ones provided for Chief and modify them and save them in the user library you can import from vendors and from the google warehouse you can make your own in Chief or other software like Sketchup Lew Link to comment Share on other sites More sharing options...
