Wall Types Missing
nancy1425
In X 12 there is a new option to Purge Unused Wall Types. I suspect you accidentally clicked on it.  I’m away from my computer right now but if I remember correctly, all of the default wall types are in the core catalog. Just go to the library, select and draw a little section of each wall type that you want added to your plan, and then delete them all. The wall types should be available in your dropdown list now.  You can also import wall types from another plan.
