skoz44 Posted July 21, 2020 Share Posted July 21, 2020 I am trying to customize some interior doors with 3/4" bull nosed edges for casing and then I'd like the label to indicate the swing direction of the door. I've been able to create the bull nosed casing; however, it does not sit flush with the outside wall. Regarding the door swing label, I was not able to find a default macro for it. How do I make the casing sit back flush with the drywall edge? Any suggestions on the door swing label? Custom macro of some kind? Thanks Link to comment Share on other sites More sharing options...
skoz44 Posted July 21, 2020 Author Share Posted July 21, 2020 Yes, that is exactly the bullnose corners I'm looking for. How did you do it? I actually found a solution to the door swing. In the Door Schedule, there is an option for which side of the door the hinge is on. Link to comment Share on other sites More sharing options...
skoz44 Posted July 21, 2020 Author Share Posted July 21, 2020 I made it as a piece of molding. Are you saying that the molding won't work as casing? Link to comment Share on other sites More sharing options...
since1937 Posted December 12, 2020 Share Posted December 12, 2020 On 7/21/2020 at 2:47 PM, solver said: On 7/21/2020 at 1:51 PM, skoz44 said: I am trying to customize some interior doors with 3/4" bull nosed edges for casing Like this? Can you explain in more detail how to achieve the bullnose edge on interior doors with the polyline molding? I'm very new with trying to customize. As you can see in my attachments, I'm trying to create a 6-1/2' long arched hallway with bullnose edging. Aside from not knowing the bullnose edge, I also don't know how to create the arch hallway... Link to comment Share on other sites More sharing options...
