Material Definitions
jayellis
Here are some ideas:
1. 3D views can be rendered using different methods. If you are using Vector View, and you make a change to the material texture, but not the pattern or color, you may not see a difference until you switch to Standard or another method of rendering.
2. The materials can be defined and assigned in different ways. For instance, the exterior finish of a wall can be defined in the Wall Specification dbx (Wall Specification>Materials>Exterior Wall Surface), or in the Wall Type Definitions dbx (this is the the default). So, if you're making a change to the material using the Wall Type Definition, but you've "painted over" that default material using the Wall Specification dbx or with the Spray Can, you won't see a change until you remove the material applied to the Exterior Wall Surface.
Posting a plan, or some pictures, will help us narrow things down.
