Steve_Nyhof Posted July 18, 2020 Share Posted July 18, 2020 I have a pony wall type with a 12" dropped brick ledge. This is used often in our foundation design to line up the main floor walls. After setting up the main floor and generating the foundation, I used my brick ledge wall type to replace the area in the circle - which works great on the level 0 floor, but does not show up on the elevation - like I didn't even add it. Would anyone like to look and see if you can figure this out? I had it working several days ago when I made it. Here is a previous post Thank you SND_D_Residential Template.plan Link to comment Share on other sites More sharing options...
Steve_Nyhof Posted July 18, 2020 Author Share Posted July 18, 2020 I think I have a height issue Link to comment Share on other sites More sharing options...
Steve_Nyhof Posted July 18, 2020 Author Share Posted July 18, 2020 I used the wall above and dragged the ledge up and then dragged the all over the one on the house foundation - that worked. So maybe a room height issue Link to comment Share on other sites More sharing options...
Alaskan_Son Posted July 18, 2020 Share Posted July 18, 2020 Link to comment Share on other sites More sharing options...
Steve_Nyhof Posted July 19, 2020 Author Share Posted July 19, 2020 Ah! I was hoping there would be direct height values to mess with - Thank you Link to comment Share on other sites More sharing options...
