cortssmith Posted June 16, 2020 Share Posted June 16, 2020 I am trying to build a shop that will have scissor truss framing and 12ft walls. I want the downstairs to have 8ft ceilings, and have the 'attic' space have vaulted ceilings with whatever head space is left over. Just enough space for some storage. I have the framing how I want it, but when I go to the rendering of the inside the ceiling will not follow the trusses. Instead the ceiling is following the roof pitch and ignoring the trusses. I have attached two pictures to show the framing, and then how the ceiling is following the pitch instead of the truss. Any help is appreciated! Link to comment Share on other sites More sharing options...
cortssmith Posted June 16, 2020 Author Share Posted June 16, 2020 Here is one more picture. I made the wall in the attic and the roof vibrant to show the difference in pitch. Link to comment Share on other sites More sharing options...
cortssmith Posted June 16, 2020 Author Share Posted June 16, 2020 It is a mess now from me clicking every button trying to figure it out, but hopefully it will help you help me Eklund Shop.plan Link to comment Share on other sites More sharing options...
cortssmith Posted June 16, 2020 Author Share Posted June 16, 2020 6 minutes ago, solver said: Is there a ceiling surface that follows the bottom cord of the truss? In the glass house view, it looks like you have Flat Ceiling checked for the attic room on this end. Attaching the plan file would help. I have attached it as a reply. I don't know if it notifies you. Link to comment Share on other sites More sharing options...
Alaskan_Son Posted June 16, 2020 Share Posted June 16, 2020 As Eric alluded to, uncheck "Flat Ceiling Over This Room". Also, uncheck "Use Room Ceiling Finish" in the Ceiling Plane Structure tab. Link to comment Share on other sites More sharing options...
cortssmith Posted June 16, 2020 Author Share Posted June 16, 2020 36 minutes ago, Alaskan_Son said: As Eric alluded to, uncheck "Flat Ceiling Over This Room". Also, uncheck "Use Room Ceiling Finish" in the Ceiling Plane Structure tab. I have both options unchecked at the vaulted ceiling still follows the roof pitch instead of the scissor trusses. Any other ideas? I feel like it has to be something with the end truss. I cannot get that truss to take the same shape at the scissor trusses. The interior wall is following the truss line as you can see in the third picture I attached, but the exterior wall is not. Link to comment Share on other sites More sharing options...
cortssmith Posted June 16, 2020 Author Share Posted June 16, 2020 22 minutes ago, solver said: Watch on YouTube: http://youtu.be/I9U-e9f8hQM?hd=1  THANK YOU so much Eric! I appreciate all this help and advice so much. Link to comment Share on other sites More sharing options...
