Renamed (Fixed) Macros
Joe_Carrick
If you've inadvertently allowed Chief to "fix" your macro name, it may cause problems when the old macro name was already being used in your plan.  This is because macro names are case sensitive and must be exactly the same as they are saved.
In order to return to the original name:
  • open the macro for edit in TMM
  • set it to "not evaluated"
  • edit  the name to the original name
  • reset it to "evaluated"
  • save - but don't allow Chief to "Fix" the name.
  • exit TMM
