Room Titles
capitaldesigns
A couple more questions. I used the insert button under room labels default and added the "room ceiling height". The text height is as large as the room title. I would like it to be 4.5" high instead of 6". Where do I change this text height ? Also the room dimensions still show up under the room title which I want to remove. The room dimension attributes is not selected under the insert button of the room label defaults. Is there some place else in the program that is placing the room dimensions under the room title ? I
