jonboy Posted March 4, 2020 Share Posted March 4, 2020 Anyone having issues in selecting objects like doors, windows, cabinets in plan view (which is not locked), can sometimes select a wall but mostly get the rooms layer ( which I have locked) . It is a plan from a couple of years back, which I saved in X12 first then started the editing process. Very frustrating any ideas. Thanks Link to comment Share on other sites More sharing options...
Richard_Morrison Posted March 4, 2020 Share Posted March 4, 2020 One idea is to read the Help menu on "Selecting Multiple Objects." There are a couple of recent features that will help you use a marquee to multiple select items without picking up extraneous types. For example, you can select a door and a cabinet, and then do a Shift-select marquee which will then only select doors and cabinets. There is also a Marquee Select Similar tool on the Edit toolbar which can be very helpful. Link to comment Share on other sites More sharing options...
jonboy Posted March 5, 2020 Author Share Posted March 5, 2020 Thanks Richard, I use marquee often but this is something else, in plan view I try to select upper cabinet and I get lower and upper and everything else, try to select a door, I get the entire wall even if the walls are locked in ALDO. thanks Link to comment Share on other sites More sharing options...
