Annotations + Dimension dialogue boxes in X12
amydutton
As Eric has pointed out, Annotation Sets have been renamed to Default Sets in X12.
If you are trying to setup the active defaults for the current view, I would encourage you to use the Edit Active View tool.  This will bring up a view specific dialog box that should have a Selected Defaults panel that will allow you to modify everything you need.  The picture below shows what you would get if you are working in a plan view.
