DzinEye Posted February 6, 2020 Share Posted February 6, 2020 I created a curved ceiling plane in this exterior porch room, but I can't figure out how to close the face above the arch? I suppose I could create a wall with an arched opening to match, but would like to know if there's a different / better way? Link to comment Share on other sites More sharing options...
DzinEye Posted February 6, 2020 Author Share Posted February 6, 2020 Look is most important, but would be nice to know how to get the framing to work if/when needed. I suppose I could do a big solid up there too... but is that the only way? Link to comment Share on other sites More sharing options...
DzinEye Posted February 6, 2020 Author Share Posted February 6, 2020 Thank you for that Eric. It kind of worked. It did curve the attic wall up high as in your example, leaving a gap, but wouldn't snap down to close it off after pulling out the ceiling past the wall and snapping it back as in your example. I ended up manually dragging the 'curve' down to close it off point by point. I may end up just going with the arched door opening solution, only problem with that is the stone wainscott has gaps at the opening. Link to comment Share on other sites More sharing options...
DzinEye Posted February 6, 2020 Author Share Posted February 6, 2020 Well what's the magic? This is what I get... Link to comment Share on other sites More sharing options...
DzinEye Posted February 6, 2020 Author Share Posted February 6, 2020 Ahaa!.. very clever. Thank you! Link to comment Share on other sites More sharing options...
