TKInteriors Posted January 23, 2020 Share Posted January 23, 2020 Hi there! When I sent a wall elevation to a layout sheet the lines become fuzzy and/or weak. Within the Rendering Technique Options dialog I change the Extend, Squiggle amplitude and frequency to zero. Within the Send To Layout dialog I send as Entire Plan/View and Live View/Update on Demand. Scaling, I send Use Layout Line Scaling. I've attached a sample. Any help in getting sharp lines will be appreciated. Kind regards, Tamela Link to comment Share on other sites More sharing options...
JHenson Posted January 23, 2020 Share Posted January 23, 2020 You should try changing the Camera View Option from Live View to Plot Lines to get cleaner lines. Make sure to use the Update all Views button on the layout toolbar when you make changes to the plans to ensure the viewports update. Link to comment Share on other sites More sharing options...
TKInteriors Posted January 23, 2020 Author Share Posted January 23, 2020 Thank you for the reply. Within the Send to Layout dialog, Plot Lines within Camera View Options is grayed out. Link to comment Share on other sites More sharing options...
TKInteriors Posted January 23, 2020 Author Share Posted January 23, 2020 Katy in Tech Support told me to send to layout in Vector or Technical View. This way I can use Plot Lines. Thanks for your help!! Kind regards, Tamela 1 Link to comment Share on other sites More sharing options...
