AlvarD Posted November 3, 2019 Share Posted November 3, 2019 I have a simple gable roof that I don't seem to be able to do it with AUTO-ROOFS. I can easily do it with manual roofs, but I'm wondering if there is any way to do it with auto-roofs. I have the default roof pitch set to 8/12, but I want to make the two gables roofs in the front at 10/12. It's easy enough to make the gable that's furthest out of the house at 10/12 by simply changing the pitch in the roof directives on the walls the roofs bear on, but the "other" gable that is created by breaking the front wall by the front door and assigning the left portion as full gable roof and the right portion as hip roof, looks right, but I can't get it to have a 10/12 pitch to match the other gable. The problem is that there's no other wall to select to set that gable over the front door to the desired pitch. I tried with roof baseline polylines, and I can see the 8/12 pitch for that gable that I want to change, but I can't select it to change it. Obviously, if I move the wall where the gable over the front door out by a few inches, then I have a hip wall that I can the pitch for, but that's not the desired effect. Thanks, Alvar Gable roof inline with hip.plan Link to comment Share on other sites More sharing options...
Alaskan_Son Posted November 3, 2019 Share Posted November 3, 2019 This is the "edge" of the roof baseline polyline that is controlling that pitch... It's just a little tricky to access. What you have to do is first drag the roof on the right either up or down (doesn't really matter which)... ...then select that edge and change it to 10/12... ...and then drag the polyline edge back where it was... 1 1 Link to comment Share on other sites More sharing options...
AlvarD Posted November 3, 2019 Author Share Posted November 3, 2019 Eric and Michael, thanks for tip. It's good to see that once you define the pitch with the baseline polyline at 10/12 for that segment, you can then delete the polyline and Chief remembers the pitch for that roof. Great use of the baseline polyline! Thanks, Alvar Link to comment Share on other sites More sharing options...
