Deleted Floor Surface in Building Design Layout
JennRob
I accidentally deleted the floor surface from my layout of a building. It appears that the top floor surface is missing leaving the subfloor. I don't know how to add a new floor surface to the subfloor (walls are built and floor plan is otherwise complete).
What software version are you using?
What steps did you make to "delete" the floor surface? If you were using the "delete surface tool" in a 3D view, the floor wasn't actually deleted; it was only removed for that view and will show if you refresh the view or close the camera and reopen.
Attaching the plan will get you a faster answer.
