Boxon1 Posted August 30, 2019 Share Posted August 30, 2019 I am working on As-Built recreation of a house, built in California, in a period of 1960-1980 (with several remodels and additions). The framing was done somewhat differently than it is usually in the other parts of the States, and the existing Plan Set is hand-drafted and equipped with very few dimensions. Most of the dimensions are site-verified, and I made some progress making a plan file, but the Chief doesn't seem to like the way this house was built. At this moment I encountered a problem that I never had before (using Chief on a daily basis since X6): After I added the roofs, this strange white belt appeared around the entire lower part of the house. I painted part of this in red, so I can identify what is it - looked like some strange belly-band, but piercing through the roof plane. -After I painted it red, it appeared to be a second ceiling plane - probably some kind of the second floor, that I can't access by DBX of any room. By the way, the room DBX shows the normal height of 97-1/8", and nothing above. No second floor. Also, at the perspective view, you can notice a gap in the exterior wall, where this ceiling plane ends. By the way, I can modify the platform option, because I need it to show properly first-floor floor joist - I already tried that. Whatever I do, I can't get rid of this plane. Any kind of help will be appreciated and welcome since I tried every trick from my bag... MacBain Av - AS BUILT.plan Link to comment Share on other sites More sharing options...
Boxon1 Posted August 30, 2019 Author Share Posted August 30, 2019 By the way, I am using X11. Link to comment Share on other sites More sharing options...
Boxon1 Posted August 30, 2019 Author Share Posted August 30, 2019 I just did, thanks. If you have any suggestions about the signature, please feel free to suggest. Link to comment Share on other sites More sharing options...
Boxon1 Posted August 30, 2019 Author Share Posted August 30, 2019 This is updated file - after I made wall framing. Framing looks normal. Can this be some problem with the ceiling framing? MacBain Av - AS BUILT.plan Link to comment Share on other sites More sharing options...
Boxon1 Posted August 30, 2019 Author Share Posted August 30, 2019 Eric, you are genius. I can't thank you enough. After I deliver this job, I will have to return to the file and figure out how that happened, but at this moment Iam just extremely happy that you found the solution. Link to comment Share on other sites More sharing options...
Boxon1 Posted August 30, 2019 Author Share Posted August 30, 2019 Thanks, Eric, I am really thrilled how fast I got the answer to a problem that took me the entire day... Link to comment Share on other sites More sharing options...
