leahg1 Posted June 21, 2019 Share Posted June 21, 2019 Good morning, Planning a porch with shed room. It will be adjacent to a sun room that has a hip roof. Shed is only thing I've come up with but haven't a clue as to how to join these two. Screened porch will go in place of arbor on pic below. Anyone able to draw? Link to comment Share on other sites More sharing options...
DavidJPotter Posted June 21, 2019 Share Posted June 21, 2019 In order to actually create such a 3D model, one would need dimensions of the existing spaces and the ceiling heights of those spaces. With that data any competent user of Chief Premier could then help you. DJP Link to comment Share on other sites More sharing options...
Jay_on_Cape Posted June 21, 2019 Share Posted June 21, 2019 Holy vent pipe Batman! Are there any bedrooms in that house or just bathrooms?? One important fact to keep in mind is that window above. You may not get enough slope in the shed roof to be able to use shingles in which case you'll have to use a rubber / TPO etc. roof. It may work but there needs to be a whole lot more info before you can receive legitimate suggestions. Link to comment Share on other sites More sharing options...
leahg1 Posted June 23, 2019 Author Share Posted June 23, 2019 Thanks all! Yes the vent pipes are quite the eyesore! And yes on slope under that window ... it is quite shallow, but will deal with it. I can provide measurements needed. Looking for someone to create the structure for me. I only have Home Designer, so this would be a draft on your software with my measurements. Link to comment Share on other sites More sharing options...
