    30418
    louisewman
    louisewman
  • Similar Content
    • By PerryPlansPro
      How do you set marker defaults in End to End Dimensions or Point to Point dimensions? Is there such a setting? I always have to open the dimension and manually change the marker settings.
      The problem that I'm having is extension lines for Manual Dimensions don't display in exterior openings which are perpendicular to dimensions. What I end up doing is cutting the Manual Dimension string and doing a Paste Hold Position. Then I modify the marker from there. What am I doing wrong?  Here's a video of what I mean.
