Mac vs PC Graphics
PhilThomas
I’m experiencing significant issues with my current laptop running Design Suite software. Looking to purchase MacBook Pro. Can anyone tell me the ideal load I should pursue in a MacBook so I can make this purchase payoff for years to come.? Thanks in advance.
You say, your current laptop is running Designer Suite Software". I assume by that you meant the Home Designer Software not Chief Architect.  There is another forum for those questions. https://hometalk.chiefarchitect.com/
If you check the hardware requirements on the Home Designer web site, it will provide the minimum requirements for running the software version you have. Most times if you bump it up a bit, in the laptop or desktop you are looking at it should be plenty to handle HDS. When you say significant issues, depending on how old your machine is, you may need to look at the Video Card it is using, and also be sure all your drivers (especially if it is 3D or other camera view issues) are updated to the latest driver.
Good Luck
