ACADuser Posted March 13, 2019 Share Posted March 13, 2019 See attached pictures. The window is recessed and mounts in the inner wall. material regions are easy but I have trouble with showing & building the framing & plan view. I tried a 20" wall with 2 framing layers but does not work well. Looks like drywall surfaces work ok with the 20" wall but not the framing. Any suggestions? St Pete TH.zip Link to comment Share on other sites More sharing options...
ACADuser Posted March 13, 2019 Author Share Posted March 13, 2019 Oh I should have remembered that trick. Thanks Eric. Link to comment Share on other sites More sharing options...
ACADuser Posted March 13, 2019 Author Share Posted March 13, 2019 OK if I use my20" wall I can not add the pass-through & if I build two walls there is a gap between the window & pass-through with no siding. How did you manage that? Link to comment Share on other sites More sharing options...
ACADuser Posted March 13, 2019 Author Share Posted March 13, 2019 I must be doing something wrong because there is an opening between the walls. File attached St Pete TH.zip Link to comment Share on other sites More sharing options...
ACADuser Posted March 13, 2019 Author Share Posted March 13, 2019 Thanks again. Link to comment Share on other sites More sharing options...
