CoyToThe Posted February 24, 2019 Share Posted February 24, 2019 There is a Hole in a ceiling platform where a platform does not exist. How do I view all ceiling and floor holes? I cant seem to find this hole in order to delete it Link to comment Share on other sites More sharing options...
Alaskan_Son Posted February 25, 2019 Share Posted February 25, 2019 I would use a different approach. Switch to the All ON layer set of anything (may not be necessary if you know the layers are on in the correct layer set), make sure all the layers are actually turned on, and then switch to the Hole In Ceiling Platform tool. Now draw a marquis around your entire plan while holding down the Shift key. This will select ONLY Holes In Ceiling Platforms. You might need to check on multiple floors, but this should whittle things down for you. 1 Link to comment Share on other sites More sharing options...
