Changing Layer
basilbabaa
When you move an object out of its default layer into a custom layer, how do you also associate the objects label with a different layer ?
For example, I made a polyline solid to use as a custom object in a plan, and I have moved it to a custom layer, but its text is still associated with Polylines, 3D, Lables so I cannot change the label text color without affecting all other 3D Polylines...
