Creating Bullnose/Rounded Drywall Interfaces
Member Statistics
Similar Content
By EdEmery12
Is there a software that works with chief that will add up materials? like flooring, drywall, doors, fixtures. Like a planswift.
By Eglazier8
I'm trying to add bullnose to a shower seat. Since Chief doesn't appear to offer bullnose tile I created a polyline solid, which worked fine until I had to join two pieces where the front and side of the top of the seat come together. Chief won't allow you to cut the ends of the bullnose at 45's and join them. Anyone have advice for how to handle this?
By Sweeney
Hi all,
Going for a more modern baseboard and door trim detail. I am wondering how to best accomplish this in Chief (see photo attached). The base board wants to be flush with the drywall plane with a 1/2" reglet reveal above. The door trim will match, and the windows have drywall returns. Has anyone ever made this happen using chief?
Thank you in advance,
Austin
By Slamnation
Is it possible to change the Wall Board (Drywall) size from the default size of 4x8 to 4x12 when CA calculates the materials list?
By B4UBLD
Surely this has been brought up before, but does anyone have suggestions for creating bullnose/rounded drywall interfaces/corners? This is in extremely common use here in the Southwest and I need to incorporate this feature throughout a plan. I know that Chief does not have this capability built in.
Thanks in advance for any help!
