grosmar Posted October 11, 2018 Share Posted October 11, 2018 Hey, I'm playing around with CA for a while but met an issue many times that I cannot eliminate. When the roof meets the wall in an angle it produces a 20-30cm hole in the wall: If I raise the wall's height, then it disappear, but from the outside look it goes through the roof then :/ I hope someone have some suggestions because spent couple of hours with it without success. Thanks a lot in advance! Link to comment Share on other sites More sharing options...
rlackore Posted October 11, 2018 Share Posted October 11, 2018 The quickest way to get an accurate response is to post the plan file, and tell us what version of CA you're using. Link to comment Share on other sites More sharing options...
