QualicoreHomes Posted August 16, 2018 Share Posted August 16, 2018 I'm doing something wrong but I'm not sure what. I'm drafting a house that will be built out of icf block so wall height is important. The house will be open ceiling with a loft in the back area. Everything went good till I drew the loft. I tried the roof two different ways as in each attached picture; (A) the one with ignore 2nd floor for the roof and the other (B) with a second floor with only an inch between the floor and the ceiling. With (A) there are spaces in between the roof and the wall of the deck and porch area and with (B) the railing only comes out of the floor by a couple of inches. Can someone please put me on the right track because I'm starting to think its next to impossible to master this program? Many thanks in advance! Stavely.plan Link to comment Share on other sites More sharing options...
QualicoreHomes Posted August 16, 2018 Author Share Posted August 16, 2018 Thanks Solver, you are sure true to your name!! Any guess why those spaces came about between the roof planes and the exterior walls when I used the "ignore 2nd story"? Link to comment Share on other sites More sharing options...
QualicoreHomes Posted August 16, 2018 Author Share Posted August 16, 2018 Sorry didn't see your second post, roofs remain tricky. Thanks again!! Link to comment Share on other sites More sharing options...
