A Curved Ramp?
photogcyn
Hello,
I have Home Designer Pro 2017.
I would like to put a ramp beside my houseplan's side porch. I would like it to start at the southeastern corner, where the main steps up to the deck begin, and then have the ramp make a U curve to continue to wind up to the porch's door, which is in the middle of the porch, the door. Can I do that with my program? I've tried and tried different ways and manners with no success.
I'm going to put a sketch of what I would like to have, since I can't in the program. I will also put a pic of what that side looks like and the dimensions.
Thank you very much.
(Not the best drawing, but I used Paint)
The last two images are from CA. The plan view and the Exterior View, where the ramps just heap up!
You can curve a straight ramp or stair section by dragging the end handle while holding down the Alt key.  You can also use the Change Line/Arc edit tool to convert from straight to curved or back.  This should even work in HD Pro 2017.
