Glass Walls
imagekit
Go to solution Solved by imagekit,
Not sure what you did but there are lots of ways to solve this problem.  Most important is to recognize the difference between changing the material for the "room" versus changing the material on the "wall".  They are two different things in the Chief world.  Also, you can put things on the wall surface and paint materials on those to change the look.
