Pony Walls Cutting Suspended Ceiling
5FT-20Designs
I am adding several offices in a large room that has a suspended ceiling.  The office walls will be 8ft and open above that.
Right now I have the walls defined as a pony wall with the lower wall as a Interior-4, 8ft high, and the upper has a blank wall created from air. When I create a camera view, the suspended ceiling is cut from the blank wall going to the full ceiling height.  Right now I do not have a roof built so it is easy to see.
I've tried a half wall (solid railing) that works except when I add a door, there is no header and the casing goes the full 8ft height.  Added a soffit above the door frame does not help, the casing still goes to the top of the wall.
Any help would be appreciated.
Thanks,
The ceiling is about 20ft high with the suspended ceiling at 12ft.
