Manual drawing of a Shed Dormer Roof
Greenshell
    30662
    VHarrisDesign
    VHarrisDesign
  • Similar Content
    • By Designer100
      I cannot get roof to work on right side of house to work out. . I would appreciate anyones help. 8:12 on for gable. rest of roofs are 4:12. Remodeling additional. dark shaded walls are new walls.
      Has to be kept in ver 12, because client wants to be able to pull up in chief 12.
      Thanks in advance.
      Newell Cheatheam
      Chief 12
      924 Cortlandt.zip
    • By jparkerrendering
      I figured this question has been addressed many times but I couldn't find it in the forum,
      I'm running into a frequent issue when creating box eaves on dormers and custom roof planes. They disappear only when the ridge is connected with an adjacent roof.
      The box eaves will reappear if I separate the roof ridge line, (as shown in my attached photos),or move my roof base line Away from the wall by the desired eave distance, or when I drag the plane inside the outer wall perimeter.
      If anyone else has experienced the same issue or is aware of a practical work around, I am all ears.
      I appreciate your time for reviewing this post.
    • By Designer100
      I cannot get the breezeway roof on the opposite side to work and slope with stairs. I would appreciate any help.
      Colburn.zip
    • By Walt_Alaska
      New to CA Architect 2021. Doing an addition that includes an attic room. I'm having trouble matching the roof and cieling deminsions for that area. It includes a flat and angled cieling plus pony walls that are also exterior walls. See the sketch with finished interior deminsions. Any help is appreciated.
    • By allieceravolo
      I am looking for some help on a roof plan I am working on (copying a 2d elevation from an architect) and can't seem to get this to look right!
      (Also, I don't typically do exterior renderings and thought I would get some practice in - but clearly have no idea what I am doing :))
