Floor heights & flat roof procedures
ACADuser
Attached is a pan I have had to adjust to ceiling heights several times during this design and now there are several issues.
One question is that to have a flat (1/4 per flor slope) roof with parapet walls is a balcony room above with a manual roo plane the best way to go?
Somehow the hole in the very top roof got a different height than the room defining that level.
Also the room does not build down to the ceiling plane, see elevation.
The light fixtures did not follow the new ceiling heights
When I tried to add a small stair to the roof access door on the left, Chief did not recognize the mezzanine floor surface.
Any insight would be appreciated.
<04/04/18> Zip file removed. I have overcome most of the issues.
