Using 2D Tool Kit for Plan Editing
Greenshell
    30739
    Dale8804
    Dale8804
  • Similar Content
    • By Doug_N
      This post moved to suggestions.
    • By SNestor
      Using X13. Have "framing default" checked for "Allow Automatic Balloon Framing"...but, as you can see in the picture below it's not working. I have auto framing walls turned on...experimented with the joist direction...didn't seem to have an effect.
      I'm on a MAC...maybe this is a reason? Does anybody know if this new feature in X13 actually works?
      Thanks!
    • By banditz
      hi anyone there, anyone can help me out with these ? wall corner & line on wall, if there is anyone can help me, i would like sending the file .. please
    • By Darrellx
      I'm using home designed pro 2021.
      Circled in the picture below is the area unfilled between the lower and upper roof where there is no wall.  I can extend the wall inward toward the peak to close the gap, but then area below the gap is closed off.  I've experimented, googled, and watched a bunch of video tutorials on roofs.  Actually seemed like one of the tutorial videos had a similar issue, but the instructor kinda glossed over it and changed to pitch on one roof to make it look a little better before moving on.
      After banging my head for a few days, hoping someone has the answer.
      (plan is also attached for the image)
      MissingGableWall.plan
    • By Ange822
      I am drawing a cross section using 2D CAD lines (to get more detail than the automatic cross section Chief creates).
      I am having issues finding a Batt Insulation Pattern to use.
      I am using Chief X9
      - Chief Architect has a Block under "CAD Blocks / Detail Components / Insulation / Batt / 5.5" R-21", but unfortunately it is only 12" x 5 1/2" of size, so if I want a smaller or bigger section, it stretches the block and the proportions change.
      - I found a free .PAT file online (attached), but It needs to be in a specific location to work, the minute I move the polyline with that pattern in it, the pattern moves with it.
      I have tried to illustrate this in the attached screen shot.
      Please let me now if anyone has any recommendations / solutions to this issue.
      thanks,
      Angela
      H1INSUN1.pat
