Counter edge apron front sink
RHDesigns
I am designing a kitchen and created a custom counter top , I then need to create an opening for the apron front sink , in the picture you can see the issue I am having is it is leaving the front edge of the counter and when I place the sink in the cabinet it still shows up ? How would I get that to do away ! I cut the whole using the counter top tool !!
Thanks
I placed all base cabinets , then created one single top , then put the arc at the outer edge, then I clicked on the entire top and then the create custom hole ? you can see it cut the hole but left the front edge of the top?
    30739
    Dale8804
    Dale8804
  • Similar Content
    • By GDChief
      Hello all, fairly new user, and I have searched through the videos and forum threads to see if my problem already exists... no luck on how to fix this so far. I cannot get my counters to sit over my machines in the plan, only under them. I have changed floor to counter heights in the dialog box and tried the "view draw order edit tools" toggle for all items separately. Can anyone let me know what I'm doing wrong? I've attached a view. As you can see, the counter is running under everything. Thanking you in advance!
